David,
Is there any way I can print all of the sessions and their information somehow?
If not, is this something I could build using an AddOn or so?
Cheers!
Sjoerd
For now, we don't have any report like this. What kind information would you expect? If it's not so much, you can export the host list in Csv from the menu File->Export
David,
The CSV export should suffice for now, but maybe I would like additional information to be exported. Like which machines have ILO configured or something. There is a lot of information that can be supplied but you cannot document it with reports or other nice lists.
BTW, the export to CSV has a flaw. When the description contains an Enter, this is also exported in the CSV. This is not working for a CSV file. Could you convert the Enters to a Space or something?
Cheers!
Sjoerd
And also the description is exported sometimes with quotes and sometimes not, this is very confusing.
Cheers!
Sjoerd
We will both problems for the next minor update. I'm aware that many other fields could be added and it's already on our todo list.
Thank yuo very much
