Integration with Database .NET for SQL Management
Hey guys,
Been using this app for a little bit now and its fantastic for Database management. Would be great to see this integrated!
http://fishcodelib.com/Database.htm
-Brendan
All Comments (12)
Do you know if this app can be called in command line?
Ineed it can David! :)
-Brendan
-Brendan
André Sanscartier
It's also available in the Add-on Manager.
André Sanscartier
Hi Andre,
That's what I call fantastic application support.
However when I try to add a new D4 session I get this error when I click on the D4 option "Unable to find Database4Net data"
Any idea's what's going wrong?
-Brendan
-Brendan
Hi Brendan,
Yes, I don't know D4 as well as you and I just realized (checking option form) that the configuration file (Database.xml) can be anywhere...
I will fix it as soon as possible next week.
André Sanscartier
D4 can be put into portable mode as well. So I would just run off the assumption that when you select where the application is (like you do with putty) that you assume the relative path from that location. (As all my stuff runs off my IronKey :) )
-Brendan
-Brendan
Hi Brendan,
Sorry for the previous message if you received it (this morning).
I was too eager to deliver and I almost forgot an important point.
Now it should work well.
Could you try it again please ?
The Add-on manager can do the update automatically.
Thanks
André Sanscartier
I will test it in the next couple of hours. But just to let you know D4 doesn't actually show up in the AddOn Manager. I'm using RDM 6.6
-Brendan
Ah, we have release the version 7.0 and the add-on manager configuration was updated for this version only. You can download it manually from the web site:
http://remotedesktopmanager.com/remotedesktopmanager/Home/AddOn#database.netsession
David,
I upgraded to version 7 today :). I'm yet to actually test a connection as im using a W8 laptop and D4 doesn't work under W8 yet unfortunately but I will be on a W7 PC later today and will test it properly then! However it did infact pick up my saved sessions which I was very happy about!
Absolutely LOVING the support for RDM!!
-Brendan
-Brendan
OK! Tested and its functioning fairly well, just a little slow! :) However is there anyway that it would be possible to get it into an embedded tab? Maybe have a chat with the developers as this app is also created in C#
-Brendan
-Brendan
