winbox for Mikrotik
Hi
Could you add winbox for Mikrotik
Thanks in advance
All Comments (6)
Do you know if this application can be called by command line?
thanks for your reply
I think this link helps you:
http://wiki.mikrotik.com/wiki/Manual:Winbox
I have sent the information to André. I will be back to work next week and I think he that he will have the time to create a small add-on for you.
thanks
As promised this is the new Winbox Add-on.
Could you test it please.
Thanks
André Sanscartier
WinboxAddOn.zip
It works
Thanks for this great work
Ends in 7 days
