RDM 9.1.1.0 extremly slow and not responding
After upgrading to Version 9.1.1.0 RDM is extremly slow and very often not responding.
All Comments (15)
What version were you using before? Could you try the 32 bit version?
Old Version was 9.1.0.0, 64 bit Version works a little bit faster than 32 bit Version
OS: Windows 8.1
DB: SQLserver 2008 but it does not matter if online or offline
Ok. What is slow exactly?
In Navigation pane expanding a folder is not responding for 3-5 seconds regardless how many objects are in this folder.
Not only expanding a folder is slow also collapsing is not responding for 3-5 seconds
Scrolling in the Navigation pane is not responding for 3-5 seconds.
But this occours not on every click , i think on every ~ 5 Action RDM is not responding for 3-5 seconds.
How many sessions do you have? Could you go in Help->Diagnostic and start the profiler?
# sessions ~ 750
LoadConnectionList : 4023 ms
LoadConnectionList...
LoadConnectionList : 389 ms
LoadConnectionList : 2 ms
LoadConnectionList : 22 ms
LoadConnectionList : 853 ms
LoadConnectionList : 1487 ms
LoadConnectionList : 9280 MS
Silent: System.Net.WebException: The underlying connection was closed: The connection was closed unexpectedly.
at System.Net.HttpWebRequest.GetResponse()
at Devolutions.RemoteDesktopManager.Managers.PingManager.get_PublicIP()
LoadConnectionList : 20184 ms
Do you use the new $PUBLIC_IP$ variable?
no !
i dont changed anything after upgrading to 9.1.1.0
i use $COMPUTER_NAME$ and $COMPUTER_IP$ in many connections
I think that I've found the problem. I will work a on fix and it should be available really soon.
OK, thank you for your help
Could you give a try to this patched version?
http://download.devolutions.net/Devolutions.RemoteDesktopManager.Bin.9.1.1.0.zip
Just unzip it.
looks good - performance is ok now
Great! Thank you for your help.
