Use system default font
it'd be great if RDM could support the systems default font. With Windows 7 GUI/Controls should actually use Segoe UI, not Tahoma (at least most applications do use Segoe UI)
Thx and kind regards,
Stefan
All Comments (2)
I know that we have a default font system in RDM but you might be right. It's possible that it's not applied everywhere.
Indeed the main treeview and the treeview in the options dialog (as well as some settings in the options dialog) are using Tahoma.
