Using SSH Tunnels to Open a Connection
Greetings,
I use the Bitvise SSH Client (http://www.bitvise.com/tunnelier) for SSH tunneling between networks. I also use the plugin to manage those connections inside of RDM.
I see that on the VPN tab there's an option for "SSH" which I'm assuming is to establish a tunnel. What I'd like is the ability to connect to Bitvise SSH Client session prior to making the connection to the parent session.
Thanks,
Guy
Hi Guy,
This is possible if you use the "Existing session" VPN type:
http://help.remotedesktopmanager.com/settings_vpn_linktoexistingsession.htm
But under "Existing Sessions," as it states, only SSL, VPN, and Web connections are listed. My Bitvise SSH Client connections that are stored do not appear in the list.
Ah! I will check that with André to include it in the list.
