Problem with Powershell Tool
Hi.
I try to run a PS-script locally, but it fails.
The script is stored on my local c:\ drive and the problem is, that RDM launches the powershell.exe in x86-Mode all the time (my local machine is x64).
And in an x86-Powershell console the executionPolicy is set to restricted and i cannot change it. when i launch an 64-bit powershell-console then i can run the script just fine.
i even tried to check the box "run in 64-bits mode" in the Tools General Tab, but it does still launch in x86-Mode.
Marc
All Comments (8)
Have you tried to run RDM 64 bit? It's included in the RDM 9.0 installer
I just did.
same problem.
Does RDM 64 tries to also open the 32 bit version of Powershell? Have you tried to use the Run As Administrator with RDM?
Yes, it does.
I am already starting RDM with a "RunAs"-Script with DomainAdmin-Credentials.
But I did try as Administrator as well, and still 32bit Powershell-Process spawns.
edited by marc on 12/4/2013
Need more Information?
I am using RDM 9.0.7.0
WIN7ENTSP1x64
PS 3.0
We found the issue and are working on the fix
Stéfane Lavergne
This has been resolved. Available here:
http://remotedesktopmanager.com/Home/Download
Stéfane Lavergne
It is indeed resolved. Thanks!
