Port scan doens't work
Hey guys
The function port scan stops working, since version 9.0.7/9.0.8. Instead of a port scan the RDM makes a ping. Would be nice if you could fix that.
Beste regards
Kilian
You were right. I have made a patch. You can wait for the next release or download the version 9.0.8.0 zip file and unzip it. This updated version has the fix included.
Perfect David, it works :-). Thanks alot.
Kilian
No problem. I broke it when I had improved the general Is online detection.
