Group view not refreshed!
Found a Bug in the sessionlist with the Status if a Session is open or not.
If you have a look at the attached screenshot you will see that the status between the general connection list on the left and the group overview on the right differs. This happens when you close a session during the time you have the group overview open, it doenst matter which kind of connection it is
All Comments (1)
thank you, it's now fixed in our internal build. It will be in the next small update.
