Command Shell Issue
Hi when i create a terminal session for example (ssh username@ip-add) the session opens but as soon as i go to type in the password it closses. This also happens for and command/terminal session even if not opening and ssh session.
any ideas?
Mac version 10.8.5
Thanks in advance
All Comments (1)
Can you send me a screen shot showing what you are doing just before the crash?
Also can you send me your log file to help find out what is happening?
It's located at ~/Library/Application Support/com.devolutions.remotedesktopmanager/RemoteDesktopManager.log
Thank you
Benoît Sansregret
