For a Putty Connection the "open with Parameters" "Prompt for Credentials" missing. It's available for RDP, but nor for Putty.
Do you use Putty with a session or with the custom parameters?
It doesn't matter which one, the "open with Parameters" is missing for saved and custom alike. I use basically SecretServer Saved credentials. I just want to be able to select different credentials or just enter them on demand. Problem is, that the username is populated to the session - thus disabling the ability to login with any user/pwd.
Thanks,
Peter
