RDP connection on non-default port
RDM Mac doesn't seem to take port configuration into account.
Whatever port number is in the port field, it still connects to 3389.
Tested on MSSQL and local database for existing or new connection.
All Comments (6)
This should work. It's possible that this is a bug. I will investigate this.
Is the port number you are trying to connect greater than 1024?
Thanks, Richard
Richard Markievicz
Yes, I've tried 3388, 3390, 3391, 3392 and 100 (just for fun :P).
As I said, this is confirmed non-functional with an existing or new connection on a MSSQL database AND with an existing or new connection with a local DB. Basically, it doesn't work at all under any circumstances in my setup.
Thanks. I've fixed a bug in how this is handled. It will be available in the next version.
Richard
Richard Markievicz
Cool! Thanks for the great support Richard!
The latest version now available (0.9.5.0) should properly handle custom ports.
Please give it a try and let me know if there's still an issue.
Thanks, Richard
Richard Markievicz
I can confirm that 0.9.5.0 fixes this issue. Thanks!
Closed
