Here's what I did..
-Downloaded beta
-Unzipped
-Copied app to Applications folder
-Launched application
-Created new connection
-Entered IP address in 'Name' field which auto populates 'Computer name:' field
-Clicked Create
-Double clicked the IP under 'Sessions'
-App crashes
Crash txt attached, please let me know if there's anything else I can provide to help. I'm running OS X Mavericks.
I also notice that the app takes longer than any other app I have to launch. I have an SSD so most apps just bounce once in the dock then launch while RDM bounces multiple times before launching. Not sure if that's in any way related but thought you should know.
Thank you for the detailed error report.
I'm going to investigate the issue and see if I can reproduce it here, then get back to you.
For the launch time, due to the framework that we use, the app is expected to launch slower than a native application. There is some overhead in initialising the Mono runtime at startup. However it is an area we will be optimising.
Can you give me an idea of how long it takes for the app to launch on your machine?
Thanks, Richard
Richard Markievicz
This issue should be fixed in the latest version (0.9.1.0).
You can use 'Check for updates' to get the new version, or download directly from the release page
Thanks, Richard
Richard Markievicz
