9.0.1.0 Template issue
When I create a new shared template 2 appear . If I rename one close RDM and Open back up they both rename. If I delete the duplicate close RDM and open back up one of them stays.
Also I imported some from an MDB source renamed closed RDM re-opened and they had all disapeared.
I only have 1 sql datasource listed
Thanks
All Comments (6)
It gets stranger/ I deleted a few duplicates closed down RDM and opened back up and both copies of the duplicate disappeared. But all the other entries lost there duplicate version ?
Do you use the intelligent cache?
Yes its set to intelligent cache
Could you try to do a Ctrl+F5 to force a full refresh?
I've turned caching off and I don't think its doing it any more.
I think when I create a template it also creates an unnamed file in the route under sessions.
I delete these and that's when strange things start happening, like duplicates.
also some time I use a template for a new data entry and the original template seems to store details that I put in the new entry
I have seen the same behaviour in 9.02
