using umlauts in stored Putty Sessions
kindly ask you to support umlauts in stored Putty Sessions on localized Windows Versions which are referenced by RDM Putty Sessions.
I figured out, that following code will do so:
// original Code for filling combobox with LoadSessions():
// this.cbSession.Items.Add(HttpUtility.UrlDecode(str2));
// working code on localized windows:
this.cbSession.Items.Add(HttpUtility.UrlDecode(str2, Encoding.GetEncoding(0)));
br,
oki
All Comments (4)
I updated the latest beta with your fix, can you give it a try ?
where can I find .16?
It's not in the .16, it's in the .15, I updated the binaries after your post.
http://remotedesktopmanager.com/download/Setup.RemoteDesktopManager.5.8.3.15.exe
edited by dhervieux on 10/25/2010
thanks. test was successfull.
