is there an option to optimize the access time to the data source? We currently started using the standard edition of RDM with an MS Access database and have over 1000 sessions in 200 groups and sub-groups. If I want to delete an empty group, refreshing the group list lasts for over 15 seconds, and doing a right-click on "sessions" even over half a minute. Compressing the database with the MS Access application did'nt have any effort. The same is with an XML datasource or the SQL database (in Enterprise trial mode). There seems to be no speed advantage of using XML or SQL instead of MS Access. The software is installed on a local network drive and should be used by 10 to 15 team members. Using the database on my local computer makes no difference according the speed.
Do you have any suggestions how to speed up thing a little bit?
By the way, it' a really great piece of software which could help us a lot to administer our customers SQL databases and remote connections.
What's also a bit irritating is the fact that if I wnat to delete a group an it's sessions, only the sessions are deleted. The group must be deleted separately.
Can you try to disable the dashboard to see if it help ? If you want, you can create a copy of your database, remove all the password and sent it to me, I will do some performance testing. Is it possible that you have many custom images for your sessions ?
Disabling the dashboard didn't help much, same performance as before. :(
Most groups contain a session with a custom icon (a command line session to a batch file), one RDP session and one Session for the SQL Management Studio.
I can create a copy and send it to you.
Let try something before, In the adavanced options of the application, you can disable the custom images.
I'm sorry, but this didn't help either.
By the way, when the application is startet, the list is shown quite fast.
Ok,
It's interesting to know that it's open quickly at startup. You can send the copy to support@devolutions.net.
I'll do a small cleanup (passwords etc.) and send it to you as soon as I'm able to.
edited by klages on 10/20/2010
Thanks a lot for your optimization. It really is much faster than before. Refreshing ist faster, the right click menu on "sessions" shows immediately, even selecting all objects now has a usable timing (before: several minutes, now: some seconds).
Thank very much!
Thank you for trusting us with your database. I did many small optimization, but the main problem is the ImageList in the .NET Frmaework. It's so slow and it's not possible to find a replacement. I hope to find more speed improvement in the future, but at least now it's more acceptable.
