When attempting to edit a sub connection, we noticed the following behaviour:
Edit the sub connection works, and gets saved to the SQL server database. The change is also visible on the editing client.
When the client exits and restarts, the change is no longer visible: the sub connection contains the old values.
When another client (with a fresh cache) looks at the sub connection, it does contain the changes, so my guess it's a local cache problem. Waiting a few days or clicking refresh does not help the issue. The particular client keeps the old (wrong) data.
Thanks.
Jelle
Jelle Hillen
More info: using online SQL Server (Azure) with intelligent caching enabled.
Jelle Hillen
Hi lunarg
I reported a similar problem with caching a couple of days ago - see http://forum.devolutions.net/topic7319-possible-v-bug--phantom-entrycaching-issue.aspx.
While the whiz-kids at Devolutions work on fixing the caching problem in the next version, the best advice I can give you comes from Stefane, which is to try using "CTRL + refresh" to fully rebuild the local cache. Note that this is NOT just a case of pressing CTRL+F5 - you have to hold CTRL on the keyboard while clicking on the refresh icon (see image below).
Des
Hi lunarg
A complete rebuild of the cache indeed works around the issue. Thanks for the advice.
Jelle
Jelle Hillen
Your welcome!
Des
@Des Bylund - thanks for the response/work around
@lunarg - thank for the bug report, I will investigate and fix the issue
Stéfane Lavergne
Jelle - Is this issue happening with all sub-sessions or a sub-session type in particular? Could you please export the session & sub-session (no credentials) and send me that via Private Message or email (slavergne-at-devolutions-dot-net)
Thanks
Stéfane Lavergne
Jelle - I got your private message thanks.
Unfortunately I'm still not able to reproduce the issue. Are you still able to reproduce in your side? With the latest build? Does it happen on very sub-connection edit?
Stéfane Lavergne
