Hi.
I started of using access database and have now moved to SQL.
I created a quite a few templates in the access database so exported them and imported them into the SQL one. However they have all imported as rdp session entries instead of data entries, is this a bug or am I doing something wrong ?
Thanks
Could you post one of your template here?
sure, here's a before and after
You were right and this is a bug. This is already fixed internally and it should be released in the Wednesday update.
