I think i've found a small bug in the the 5.5 preview (build 5.4.9.6):
When i have multiple embedded RDP sessions open and i then click on the tab of a RDP session to switch to that RDP session i noticed that a small RDP window very briefly appears and then disappears again.
Switching does work though, but it looks a bit odd.
edited by ruudboek on 5/12/2009
Can you telle me where this window appear exactly ?
Devolutions inc.
Yes, the window appears in the top left corner of the rdp session window. It has a size of about 6 cm and appears only for a split second.
I run RDM on Windows XP SP3.
Ah the small windows seems to no longer appear when switching sessions in the latest build 5.4.9.7. Very good. :)
Maybe not that important, but i now noticed that that small window also seems to appear briefly when you open a new session. It's not that much of a problem though, but if you want to perfect it...
Hi David,
just to let you know: the problem of a small window appearing when opening a new session seems to be solved in version 5.4.9.9.
Excellent, all these bugs were in the Microsoft .NET Framework, but I found some workaround...
Thank you
Devolutions inc.
