Hi ,
first of all I want to thank Devolutions for this great rdp tool.
I recently switched from Terminals to Remote Desktop Manager and imported all rdp connections via the import wizard.
Yesterday I wanted to add some groups to have a clear view and moved some sessions from the overall group "sessions" to a group.
But those sessions only move one group forward. for example:
order of the groups:
Group "test"
Group "test2"
Want to move the session SERVER1 from the overall group to "test2" and it moves the session only to "test". I tried it several times with more than 3 groups to move one session to the last group in the list and it doesnt work, just the next group in the list.
Is it a bug , an issue or misconfiguration of me?
Thanks in advance!
edited by soluble on 8/19/2010
This must be a bug but I unable to reproduce it. CAn you send me by email a printscreen, maybe I will see something, also if can send me an export without the credentials, I will try to reproduce the case
Thanks for the quick answer. Just to give your more information: I am running RDM on Windows 7 - 64 bit.
edit:
So I tried it again and it works. Before I drop the sessions in the specific group I have to wait a second or two with the selected sessions over the group. A "quick" (select sessions and drop it quickly to the chosen group) drag and drop doesnt seem to work.
Not that big issue for me. I added about 70 RDP sessions, maybe it is too big ?
I will investigate, maybe the drag over has a delay because of the size. Can you try just with 2 or 3 and see if you have to wait ?
With only a few connections it works "faster" (I would say normally)!
