Links within Text sessions do not work 5.8.2.1
Links within Text sessions do not go anywhere, the hand comes up but does nothing when you click it.
I'm not sure if this has been posted already or not. I didn't see anything.
Also, it'd be nice if you double click on it to view the text if you could also modify it directly from there instead of having to go to edit session.
Awesome product btw. :)
edited by kdrude on 8/9/2010
All Comments (2)
You're right, the link are not implemented, this will be in the next minor update. I entered a feature request for the "live" edit text
Works great in 5.8.3.0.
Thanks for the fix!
Ends in 6 days
