Local devices on remote session does not work
first I want to say that I use RDM since two days and it´s fantastic - many features, easy to use and so helpfull.
I found just one problem, If I want to use specific drives (not ALL!) in the remote session for Remote Desktop I don´t see the selected drives. If I use all drives it works but with selected it doesn´t.
This problem also exists If I make a manuall remote desktop session. It since I use RDM.
Do you know what causes this problem?
All Comments (2)
I think that it's related to your version of Remote Desktop Client. I suppose that you use the version 6.1 and you haven't updated it to RDP 7.0?
http://support.microsoft.com/kb/969084
They changed the way of specifying the drives in RDP 7. Let me know if it helps
Thank you David, you are right RDP 7 solved this problem. Thank you very much!
