Problem right after startup
Hello!
First of all: Congratulations to this awesome product - I'm just using it for a few hours but I'm really excited about it's features!
Right after creating some sessions and restarting the application I got the following error message:
ArgumentOutOfRangeException - InvalidArgument=Value mit dem Wert 2 ist für index ungültig.
Parametername: index
bei System.Windows.Forms.ListView.ColumnHeaderCollection.get_Item(Int32 index)
bei Devolutions.RemoteDesktopManager.Frames.ConnectionViews.FreConnectionListView.InitListViewColumns()
bei Devolutions.RemoteDesktopManager.Frames.ConnectionViews.FreConnectionListView.LoadConnectionList(Connection[] connections)
bei Devolutions.RemoteDesktopManager.Forms.FrmMainBase.LoadAllConnectionView(Boolean saveState)
bei Devolutions.RemoteDesktopManager.Forms.FrmMainBase.RefreshAllConnectionView(Boolean saveState, Boolean checkOnline)
bei Devolutions.RemoteDesktopManager.Forms.FrmMainDockable.tmFirstLoad_Tick(Object sender, EventArgs e)
bei System.Windows.Forms.Timer.OnTick(EventArgs e)
bei System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
After the startup I can't change to the "All Sessions" tab. Trying so also gives the error message above.
Please advice.
Thanks in advance!
Daniel
All Comments (2)
Wow - thanks for your quick reply!
Now it works perfectly!
