Problem with embedded rdp session
I'm usng v5.8.1.0 standard edition. The first embedded rdp session close after I logon on the second embedded rdp session.
So I cann't use multi embedded rdp session. Please help.
All Comments (7)
Do you connect on the same machine ? If you inverse the connection order, do you reproduce the problem? What OS do you have ?
edited by dhervieux on 7/21/2010
I'm using windows 7 32-bit. I've tried to connect to four different servers, the order does not make any difference at all.
It close the first embedded session just after I logon on the second embedded session. These servers belong to the same Vmware-server.
Ok,
Can you go in the application options and set the debug level to 1. After that open the application log (menu Help->Application Logs) and check if you see something.
If you open your connection in external mode, do you have this behavior ?
I can open them simultaneous with windows rdp.
The application log give: [21/07/2010 14:24]INFO RDP - Disconnect:2824
edited by Dragonsight on 7/21/2010
We are not lucky the error number 2824 is not listed:
http://msdn.microsoft.com/en-us/library/aa382170(VS.85).aspx
Do you open the session in Admin /Console mode? If you connect to another machine, not related to the virtual server, does it work ?
I turn off admin/console mode and it's now working fine, Thanks.
