ver. 5.8.0.1, datasource SQL 2008R2 - default settings, logged in user has all SQL server administrative roles, offline mode enabled, windows 7 64bit
when working offline, RDM does not use stored credentials for RDP sessions - we have stored all of them in the same SQL database as credential repository entries.
I will verify, this must be a bug and I will fix it quickly
Hi, any progress with this? This seems to be really serious problem :-(
This bug is high priority and it should be fixed in the next minor update. We try to release it soon
Can you try this version:
http://remotedesktopmanager.com/download/Setup.RemoteDesktopManager.5.8.1.3.exe
Hi, thanks for this fix - it works like a charm...
We're using the latest version and find this to be an issue. Has the bug returned?
Unfortunately, I must confirm lowellp's experience - it's back. dhervieux has already been informed two days ago :-)
I need you help because I'm unable to reproduce it. Do you use any user setting overrides, is it linked to a specific session type. Could someone tries to create a new data source with only one session and try to reproduce it?
Hi, David! This problem occurs for us at least in the following scenario:
We are using now RDM 7.5, seeing the same behavior as the previous version.
We're using SQL Azure.
RDM starts, connects fine to the data connection.
Internet goes down at the site we're physically located.
Try to connect to machines on the local network via RDM... after a minute or so, when RDM can't connect to the data source it will ask if we want to go offline.
Choose offline mode, but then every time we try logging onto a connection we're being asked for credentials.
I just tried while online, and then switching to offline mode manually, and for the last few minutes it's retaining credentials. Of course, in this scenario I do have Internet access; I'll see what happens past 5-10 minutes and post here.
How the credentials are linked? Is it with a embedded or a link?
They are linked to the credential repository. So I'm trying a few different scenarios. It seems to be working fine while forcibly turning RDM offline so far, at a site that has Internet access. So the scenario where it hasn't worked is this:
Working on laptop in the office with RDM online.
Sleep the laptop, take to coffee shop.
Get on coffee shop wireless, am able to connect to any sessions that were open.
(In this scenario, the SQL Azure firewall isn't allowing access to the database because the coffee shop WiFi isn't an allowed IP address... so we're asked if we want to go offline, yes)
Am able to open new sessions without having to logon to the server/computer, but only for a while (not sure how long, maybe a few minutes).
Eventually it's like RDM ignores the credential repository, and we have to enter in credentials manually in order to access sessions.
So maybe when RDM is forced offline at a site that has full Internet access (thus access to SQL Azure) maybe it's still accessing Azure via the Internet still?
Another question, the credential entry is a normal one? I mean it's not in keepass or another app?
It's just a normal one inside of RDM.
Happy i'm not the only one with this problem.... when completely off-line passwords are not filled in, but when 'off-line' but sql server in background still available no problem with passwords.
Waiting for solution ...
I've just tried to reproduce it and I'm unable to. Could you send me a print screen of one of your session and also one of your credential entry. I must have a different setup than you.
Do you use the user specific settings?
We setup a credential entry using "Username / Password". So we have a username in the "User name" field, domain in the Domain field, and password in the Password field. When we create a connection (session) in the Credentials field we choose "Credential repository" and then browse to the credential we saved earlier. Does that answer your question?
(BTW, thanks again for being so attentive to the forums, to issues, and requests. This is rare these days and is definitely one of the reasons we moved to RDM.)
Next week, I will send you a special build with some debug info. I really tried many scenarios and I can't reproduce it. It must be missing something.
