RDP via TS gateway does not work
Hi, I have the latest RDM installed and am using the latest Microsoft RDP client release. I have a number of file-based RDP sessions that connect via a terminal server gateway over the internet, with a trusted root certificate from our company. As a standalone file, connectivity is fine. However, if I try to import the session, it does not work. I have verified that all the correct options are set in the terminal server gateway section of the session, but no luck. Any ideas?
Do you connect in embedded mode or external mode ?
Embedded - Doesn't work... Attempts to connect, but doesn't appear to use the TS Gateway
External mode - works great.
edited by kdrude on 8/9/2010
Can you send me the exported rdp file to support@devolutions.net?
