This may be an easy one but cannot find an option for it.
When my computer restarts I have to repoint RDM to the SQL database every time and its really starting to get annoying.
Offline mode is enabled which I though might cure it but it doesn't as I have come into work today restarted my machine and it has lost connectivity.
Any help much appreciated?
What RDM version are you running?
Not sure I understand "I have to repoint RDM to the SQL database" can you post screen shot or the error message you are getting.
Thanks
Stéfane Lavergne
where is your config file located?
Maurice
