Dameware as quick connect engine
We have purchased the enterprise version and need to have Dameware as an option in the top quick connect bar.
We just want to be be able to select dameware, type an IP and away it goes...
is this possible?
All Comments (2)
I never tried, but I think that if you create a Dameware template you will be able to use it in quick connect and specify the IP. Can you give it a try and let me know ?
Yep, that's worked. Cheers
