I've been hunting around in the options menu and so far I haven't found a way to make the default (when double clicking a connection) action be to open a new connection in embedded / tabbed mode. Is there a way to do this? The only thread I can find with a similar question is this one:
http://forum.devolutions.net/messages.aspx?TopicID=387
and although an option to create all new sessions as embedded is mentioned, I can't find it anywhere. The only place I can find anything similar to that option is under the quickconnect options. Could someone point me in the right direction?
It's available in the session properties under folder / group. Resize the window or scroll down the top section, you will see it. Check the screenshot from here: http://help.remotedesktopmanager.com/index.html?embedded_vs_external_mode.htm
Oooh, thanks!!
