BETA 5.8.0.2 Truncated Virtual Machine Names/Vbox
In the connection tab for Sun VirtualBox, there's a drop down list of defined Virtual Machines. If the Virtual Machine name includes a space, only the first word is shown and any launch will fail as the name will be incorrect (truncated).
I added a bug report, thank you, I will fix it soon.
Hi David,
This also happens in BETA 5.8.0.5 for VMware Infrastructure Client. The user name is truncated at the [space].
Work around is to have the user name in quotes.
Side Note: I don't know what I'd do with out RDM. It's a brilliant application. Well done.
First of all, thank you very much, I really appreciate your feedback. I added a bug for VMware.
