Strange problem with Entra ID SSO to Delinea Secret Server
a colleague had the problem, that his RDM was not starting. We just saw the splash screen, and then nothing happened. After playing around a while we found out, that it had to do with his \AppData\Local\Devolutions folder. After we deleted it, RDM was starting.
But now we have a new really strange problem on his client.
When we start RDM and then try to access secrets stored in Delinea Secret Server, we are signed in with Entra ID SSO and a MFA prompt appears. This is working for all of us. But not for the colleague that had the starting problem.
When he tries to access Delinea, he gets an Entra ID sign in page. But the only authentication methods offered are SMS and certificate. It does not matter what we choose, the result is that his device is seen as unregistered (we use Entra ID conditional access). When he uses the same URL in Edge or Chrome on his client, it is working as expected with SSO + MFA.
I tried to fix it by uninstalling RDM, deleting \AppData\Local\Devolutions - does not work.
Then I had the idea to use the portable version of RDM. I downloaded the latest portable version, copied it to a folder on his computer, copied our default.cfg, started RDM and everything is working as expected! Select "View password" on the Delinea Secret Server entry, SSO works and after entering MFA, all his secrets are shown.
What I also tried is starting RDM with "run as Administrator". This way Entra ID SSO is working, and I get the MFA prompt, but it behaves strange (mouse is not working, have to use keyboard and tab to enter the MFA numbers)
Has anybody ever seen something like this? Any idea how to troubleshoot this? It looks like the browser is running in some kind of private mode with the installed version is used, but this can´t be true as the setting in RDM is not active.
Thanks a lot for your help!
Brgds Andreas
All Comments (7)
This is indeed a really strange issue.
You've already done quite a bit of investigative work by deleting AppData\Local\Devolutions and trying the portable version.
Since it works with the portable version and as an admin, it would lead me to believe there's a file stored somewhere that the installed RDM version accesses per user that isn't in AppData\Local\Devolutions.
To help narrow it down further, which version of RDM is your colleague using?
Jonathan Lafontaine
now 2026.3.19 for installed and portable. But it was the same with 2026.3.17 he had installed before.
But what could be accessed by the installed version, that is ignored by the portable? Also the WebView2.Cache is different. Could browser cache or cookies do something like this?!?
Brgds Andreas
Thank you for providing the version.
I don't think the browser cache or cookies are the cause, no. At least not at this point. Moreover, deleting the appdata folder should have cleared the browser cache/cookies.
However, since you mentioned the SSO login acts as if the computer is not unregistered, I think it's worth checking if Single Sign-on with Windows account has been somehow disabled.
In RDM, go to File menu > Settings. In the tree on the left, go to Entry types > Sessions > Website, then open the Microsoft Edge tab.
If "Enable Single Sign-On with Windows accounts" is set to false, that might explain the issue.
Jonathan Lafontaine
Unfortunately the colleague is already at home, I can check this tomorrow. But when I remember right, this setting is default. And it must be default because we deleted the whole appdata\Devolutions folder which hold all those local settings.
And it is not the case that it is not doing it! it is presenting the login.microsoftonline.com window and asks for our smart card or SMS. It does not offer password or any other "modern" authentication via MS Authenticator we use.
And what I also tried - it does not matter if I set the default browser to Edge or Chrome. I don´t know if this popup windows relies on this setting, but I tried it...
What I can try tomorrow is to rename AppData\Local\Microsoft\Edge temporary to reset Edge to its default.
Brgds Andreas
Yes, we can try that.
In the meanwhile, I'll keep investigating the code in case I can figure out if other elements live outside appdata\local\Devolutions.
Jonathan Lafontaine
yes - that is the interesting part. Why is it working with portable, ant not with the installed version on the same computer at the same time!
Brgds Andreas
Thank you for the detailed description and for the troubleshooting you have already done.
Since the portable version works on the same machine while the installed version does not, it would be best to look at this together in a remote session. I will send you a link through a private message so you can book a time that suits you and your colleague.
Please make sure your colleague is available during the session, since the issue only happens on his computer.
Carl Marien
