Proxmox (Beta)-session - issues with NoVNC Session over Port 8006
Hello Devolutions team,
The Proxmox (Beta) entry in Remote Desktop Manager connects successfully to the cluster over HTTPS on port 8006 and lists the nodes and VMs. However, clicking Console for a running VM opens an embedded VNC tab that eventually reports a connection timeout. The same VM opens successfully in the Proxmox web UI using noVNC, with the same URL and account.
Environment
  • Remote Desktop Manager for Windows 2027.1.1.0 Beta
  • Proxmox VE 9.2.26
  • Ticket authentication using the same Proxmox realm and account in RDM and the browser
The issue occurs with both the cluster FQDN and the direct FQDN of the node hosting the VM. Switching the embedded VNC engine from IronVNC to FreeVNC produced the same timeout. The Proxmox task history shows that a console task starts on the correct node and ends with connection timed out after 10 seconds.
With FreeVNC logging enabled, the client resolves the node FQDN successfully, then attempts a direct TCP connection to port 5900. That connection times out with Winsock error 10060. The relevant log lines are below, with the hostname redacted.
[DEBUG][freevnc] - [freevnc_transport_resolve_host]: getaddrinfo <node-fqdn>:5900
[ERROR][freevnc] - [freevnc_transport_tcp_connect]: connect failure: 10060
Can the native Proxmox console in RDM use the vncwebsocket endpoint over HTTPS on port 8006, as the Proxmox web UI does? If so, which setting enables it? If direct VNC is the expected behavior in this build, is WebSocket support planned for the native console?
Thanks,
Tobias
All Comments (4)
Hi Tobias,
Thanks for the detailed report. Your logs point to the cause.
The most likely issue is that TCP ports 5900–5999 are blocked between your workstation and the Proxmox nodes. The Proxmox web UI never needs those ports, because noVNC tunnels the console through HTTPS on port 8006. RDM's VM console works differently in this build:
  1. RDM asks the Proxmox API (port 8006) to open a console for the VM.
  2. Proxmox opens a one-time VNC listener on the node, on a port between 5900 and 5999.
  3. RDM connects directly to that port.
If step 3 can't reach the node, you get exactly what you saw: the connection times out on RDM's side (Winsock 10060), and the Proxmox task ends with "connection timed out" after 10 seconds. This is also why switching between IronVNC and FreeVNC made no difference: both connect the same way.
We built the console assuming those ports would be reachable, and we hadn't considered environments where only 8006 is open, like yours. There's no setting in this build to change it.
In the meantime, if you are in a position to do so, opening TCP 5900–5999 from the RDM workstations to each Proxmox node should let the console connect. Check both the Proxmox firewall and any network firewall in between. Each console session can get a different port in that range, so the whole range needs to be open, not only 5900. If the console still times out once the ports are open, please send us new FreeVNC logs and we'll look into it further.
I've opened a ticket to explore running the VM console through the websocket over port 8006, the same way the web UI does, so this extra firewall rule would no longer be needed. I'll keep you posted on its progress.
Jonathan Lafontaine
Thanks for confirming how the native console connects. My access is limited to the Proxmox web UI and RDM, so the proposed firewall change would need to go through our infrastructure team. The browser console works over HTTPS on port 8006, so that covers the immediate need.
Support for vncwebsocket over port 8006 in the native RDM console would be very helpful for our setup.
Tobias
I have good news then.
With IronVNC now being fully integrated in RDM, websocket access through port 8006 wasn't as big a hurdle anymore.
I implemented the remaining pieces yesterday.
Future versions of the 2027.1 beta and the release will be able to connect to Proxmox's consoles through port 8006 directly.
Jonathan Lafontaine
Thanks for implementing this so quickly. WebSocket access over port 8006 addresses exactly what we need for our Proxmox setup.
Happy to test it against our cluster and report back.
Tobias
