Using stored sessions with WinSCP
I've got numerous stored sessions set up in WinSCP. How can I set up RDM Sessions to use these? (If I create an FTP type session in RDM, I don't see anywhere to specify a session or a command line option.)
All Comments (7)
Do you know if it's possible to pass it in command line ? If it's possible I could add this in a future version.
Yes. There are extensive command line options documented here: http://winscp.net/eng/docs/commandline.
Thank you, I missed it. I added a feature request. I will try to add this soon.
Wow! Looks like it's already in the latest beta 5.8.0.2 and works well. Not sure if this is possible, but it would be great if Remote Desktop Manager could read the list of WinSCP sessions (similar to what you do for Putty). Thanks for the great and speedy enhancement!
edited by jalperin on 5/6/2010
Yes I did that before the release. Sometime, I don't have the time to do major feature and I pick a small one. I will eventually try do find where the session are stored, but if you have the time to look at it, it will help me.
I found it in the registry, it will be in the next beta.
Are you still hoping to add command-line parameters for WinSCP? I'd like to use the
-privatekey=<privatekey.ppk> option so that I can use private keys to connect through WinSCP.
Thanks!
