1 vote
Please add an option to configure the width of the vertical scrollbar in the Navigation pane (left-hand server and folder tree).
The current scrollbar is extremely thin, making it difficult to grab and use, especially on high-resolution displays.
Important: Windows registry settings do not solve this problem. I have tried modifying the ScrollWidth value under:
HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics
After restarting Windows, the standard Windows scrollbars become wider, but the scrollbar in Remote Desktop Manager remains unchanged.
This suggests that RDM uses its own scrollbar implementation or styling.
An adjustable scrollbar width setting would greatly improve usability.
Ideally, users should be able to choose between several widths, for example:
8 pixels
12 pixels
16 pixels
This would make navigating large server and folder lists much more comfortable.
I've moved your thread to the Remote Desktop Manager forum as that seems to be the product you're using.
As for your request, is your goal for this setting to apply to every scrollbar, or only in the navigation pane? If it's mainly in the navigation pane, then I think it should be simple for us to add. If you can confirm this for me, I'll open a ticket so we can work on this.
Excellent suggestion, we have logged a ticket and we will look into the fix!
Thanks,
Paul Dumais
