SSH Connection stuck when switching Apps longer than 5sec
Hello, i have the problem with the current version 2026.3.1.5 (also in the previous versions) on my Samsung Galaxy S26+.
If i go into another app while having a SSH session open, if i switch into RDM within 5 seconds i can type without problems, after 5 seconds the keyboard is there, but i can't type into the session, it is stuck.
If i want to e.g search up a command, i always have to manually close and open the session again, which of course is pretty much unusable.
I would be very thankful if this could be fixed. Thank you
Thank you for reporting this issue. We will investigate.
Best Regards,
Nicolas Dufour
We have reproduced the problem and are working on a solution.
In the meantime, here is a workaround you can try:
  1. Go to the app's info page on your phone (long press the app icon > click the ⓘ)
  2. Scroll until you see a Battery section and click it
  3. Set battery usage to Unrestricted.
This should prevent the loss of keyboard function while the app is in the background.
Best Regards,
Bea Racine
Thank you very much for your answer and the fast workaround.
I can confirm it works now with battery set to "Unrestricted". Ideally this should not be needed of course.
Love the App btw! Thx.
