Focus issue with undocked RDP session
A fix for this issue has been implemented in version 2026.3.18.0
Hi there!
Since 2026.3.16.0 I have an issue with undocking a RDP session.
Opening two RDP sessions, one embedded, one undocked.
When I click on my undocked one, the RDP main window goes to grey showing the undocked entry tab (a little window with buttons "Close", "Focus" and "Dock" appears).
This way, I cannot use two RDP sessions next to each other.
In 2026.2.17.0, when you activate the undocked one, the embedded one still stays visible in the main window.
Thanks!
Recommended Answer
Just installed and tested 2026.3.18.0 and it works great! Thanks!
All Comments (4)
Hi sander02,
Thanks for the clear description, we were able to reproduce it. Since 2026.3.16.0, clicking into an undocked session switches the main window to that session's placeholder tab, which hides the embedded session. That's a regression, not something you can change in the settings.
Our development team has already fixed it, and the fix is planned for the next release, 2026.3.18.0. Please note that 2026.3.17.0, which is out now, does not include it yet.
Until then, there are two options:
  1. Undock both sessions. The main window can still switch tabs, but both sessions stay visible in their own windows, so you can work with them side by side.
  2. If you need the previous behaviour right away, you can use the current stable version, 2026.2.20.0, until 2026.3.18.0 is available.
We'll post an update here when the release is out.
Eduard Sepulveda Lopez
Thank you for your patience while our team looked into the issue you reported.
I'm happy to let you know that the latest version of Remote Desktop Manager (2026.3.18.0) includes a fix for this problem. You can download it from our website here:
https://devolutions.net/remote-desktop-manager/download/
Once you have installed the update, could you please test it in your environment and confirm that everything now works as expected? If the issue persists or if you notice anything unusual related to the same original problem, just reply to this message with a few details, and we will be glad to look into it further.
Érica Poirier
Hi sander02,
Great to hear, thanks for testing and letting us know!
We'll mark this thread as solved. If it shows up again or you run into something else, feel free to open a new topic.
