After establishing a Telnet session with the device, no real-time content is displayed. How should I set it up? For specific questions, please refer to the video.
Hello Hao,
Thank you for contacting Devolutions Support.
Could you let me know if the same Telnet entry showed the device output normally in 2026.3.15.0? It would also help to know if the output appears in real time when you connect to the same device with another Telnet client, such as PuTTY.
If it only happens in Remote Desktop Manager, please set the entry’s log verbose level to 2, reproduce the issue once, and attach the log file to your reply.
This will show us whether the device output reaches Remote Desktop Manager but is not displayed.
https://docs.devolutions.net/rdm/knowledge-base/how-to-articles/send-ssh-shell-logs-and-verbose/
Samuel Dery
Hello Hao,
I'm very sorry. I tested MobaXterm 26, SecureCRT 9.7, and putty, but they no longer appeared. However, in my memory, they were always visible. Maybe there's a problem with my settings after the update. I will investigate the cause. Thank you very much for your reply.
Hello Hao,
Thank you for testing with the other clients. Since the output is also missing in MobaXterm, SecureCRT and PuTTY, this points to a setting on the device or in the session path rather than Remote Desktop Manager itself. If it helps, you could compare the device’s terminal and console output settings with how they were before the update.
If you find that the output displays correctly in the other clients but still not in Remote Desktop Manager, please let us know and we will look into it further.
Samuel Dery
