WebDAV entry: item names lose their first character when Home directory is “/” (hrefs not resolved against the request URL)
RDM 2026.3.16.0 (Windows), WebDAV session entry against a small embedded WebDAV server (Pi1MHz firmware, HTTP, no authentication).
The Home directory field is mandatory, so for the server’s root I set it to /. RDM then sends PROPFIND // HTTP/1.1 (Depth 1, User-Agent DevolutionsWebdavClient, allprop body; captured with a logging relay in between). The server answers 207 Multi-Status with valid absolute-path hrefs; the display names are the full names:
<D:href>/</D:href> <D:displayname>/</D:displayname>
<D:href>/Backup/</D:href> <D:displayname>Backup</D:displayname>
<D:href>/tdisc/</D:href> <D:displayname>tdisc</D:displayname>RDM lists every item with its first character missing: ackup, disc, emos ... (all 27 folders and files). It looks as if RDM removes the length of its own request path (2 characters, //) from each href, instead of resolving the href against the request URL (RFC 4918 lets the server use any href form for the resource; RFC 3986 section 5 for the resolution) or using displayname.
Controls: Windows Explorer (WebClient) lists the same server correctly. With curl, PROPFIND on / and on // return identical hrefs, so the server is consistent; only the request path differs. An independent server, rclone 1.75.2 (rclone serve webdav), answers // the same way: 207 with the same /-prefixed hrefs as for /. RDM shows the same shortened names against that server too.
Could you please (1) resolve each href against the request URL (or use displayname) when building the list, and (2) accept / as the home directory without producing // in the request? An empty home directory would also do, but the field cannot be left empty.
kind regards
Mark
Thank you for the detailed report and the captures, they made this very easy to test.
I reproduced the issue in our lab with RDM 2026.3.16.0 and an rclone WebDAV server.
With the Home directory set to /, RDM sends the request to // and every item loses its first character.
The subfolders also cannot be opened, because RDM then asks the server for the shortened names.
I confirm this is a bug in RDM, not in your server.
I reported it to our QA team with both of your requests.
The first is to build the names correctly from the server answer.
The second is to accept / as the Home directory without sending //.
I will let you know as soon as a fix is available in a release.
Best regard
Carl Marien
Thank you for your patience while our team looked into the issue you reported.
I'm happy to let you know that the latest version of Remote Desktop Manager (2026.3.17.0) includes a fix for this problem. You can download it from our website here:
https://devolutions.net/remote-desktop-manager/download/
Once you have installed the update, could you please test it in your environment and confirm that everything now works as expected? If the issue persists or if you notice anything unusual related to the same original problem, just reply to this message with a few details, and we will be glad to look into it further.
Maxim Robert
