Since updating to 2026.3.15 i'm seeing a problem with RDP sessions appearing to freeze if RDM is minimised for a while.
When you return to RDM the session looks ok but you can't click on anything and the keyboard appears not to work.
If you hit enter the screen partly redraws indicating that the windows session locked the screen due to inactivity timeout so is waiting for you to enter the password but the actual display had not updated in RDM due to it being minimised.
This has never been a problem before, so appears to relate to the latest version of RDM (not sure what version I was running before the update, but I keep it updated so whatever the previous version was)
Hello Steve,
Thank you for the detailed description.
I tried to reproduce the problem on my side with RDM 2026.3.15. I minimized RDM with an RDP session open, waited for the remote Windows session to lock, then restored RDM. The session redrew correctly and stayed responsive, so I couldn’t reproduce the freeze.
To try again under the same conditions, could you tell me:
How long is RDM usually minimized before the session looks frozen? Roughly how many minutes or hours?
Does it happen every time RDM stays minimized that long, or only sometimes?
Which RDP engine is the entry using? (Entry properties > General > RDP client / Display: Microsoft “Latest” or FreeRDP?)
What is the screen lock timeout on the remote machine, and what OS is it (e.g. Windows Server 2022, Windows 11)?
Is the session embedded (a tab in RDM) or external (undocked)?
With that information I’ll run a test with the same timing. In the meantime, if it happens again, you can try View > Refresh or resizing the RDM window. Please let me know whether either one brings the display back.
Carl Marien
I'm connecting to a Windows 11 system that has a 10 minute timeout before the screen locks.
I run it embedded in a maximised tab. On Properties General it shows RDP Type Normal (I don't see the other options you mentioned)
If I leave RDM maximised but pull things over the top it correctly locks the screen, redrawing correctly when I switch back to RDM.
If I minimise RDM and pull it back up later (no specific time maybe 15 minutes maybe an hour+) the screen generally looks "normal" but doesn't respond. If I have multiple tabs open, switching to another tab and back causes it to redraw the screen and show the lock screen correctly.
Thanks,
Steve
Hello Steve,
Thank you for the extra details.
I’ve opened an investigation with our QA team so they can try to reproduce this under your conditions. I’ll keep you updated as soon as I hear back from them.
In the meantime, switching to another tab and back should get the session responding again.
Carl Marien
