1 vote
Please consider the option in the Navigation Pane to filter on opened sessions only. At the bottom, click on ... , filter option, Show Opened Sessions Only would be really helpful.
I have lots of ssh sessions in folders, when I open the sessions they are up and down the navigation page, it would be easier to filter on opened sessions only in the Navigation page so if I want to select the opened sessions to execute a command / typing macro, it would be easier to select the opened sessions.
If I goto opened sessions I can select the SSH sessions however when I right click I do not see the option to execute a command / typing macro. Another option would be to allow the same right click property context menus when in the Navigation pane in the Opened Sessions pane.
I think both solutions would make sense and help depending on the workflow users enjoy. I'll open two internal tickets for this: one to add a navigation pane filter option to only show opened sessions, and one to improve the Opened Sessions section's context menu to allow the full breadth of actions.
I went to check and for the navigation pane we already have this navigation option, could you try it out and see if it works for what you need?
If it does, then I'll only open the ticket to improve the Opened Sessions section as that doesn't have options you need.
Yes, I see the Show only opened session's option, not sure how I missed that, thx.
Perfect, I'm glad to know that this works how you'd hoped. We'll still see about adding a more complete context menu for the "opened sessions" but I will consider this request solved for the most part. If it ends up not working how you'd wish, let us know and we'll revisit this.
Thank you
