Problem with Web Logins - Firefox
Hi, after a long one year absence from my favorite utility at last my new job is needing it back.
I must say that the new whole interface took me by shock to get used to it but i still trying to make things the old way. One of them is the web login.
Normal scenario, i use firefox to enter a VCENTER. devolution plug in asked for me to save the credential, i select and it saves the credential and the URL that uses that credential (you can have multiple urls)
Then i went and add an entry, web site with the link of vcenter and open with firefox. when i double click the entry the vcenter opens the fields are green and username/password is filled and auto submit the form.
Now that is not happening.. First of all if i add a credential for the site and the site as an entry devolutions shows two password entries on the field
I did the other method, open firefox and open VCENTER i see the credential and added then a UI opened in the VAULT that i add name, folder, username password
a normal entry is added in the RDM, i double click but again the same happens, no auto fill-no submit even though it finds the credentials.
What am i doing wrong?
Also does the scenario with web credentials and a list of URLs is not working like before. I mean many web sites have the same password/username so i used to go to the credentials of web and add the equivalent URLs and that was it.
Pleas assist
RDM for Windows 11
Purchased Enterprise Edition v2026.x
Recommended Answer
Devolutions Password Manager Browser Extension for Firefox 2026.3.2.1 is now available, including improvements to “Automatically autofill on load” (autofilling without having to manually select an entry) and “Auto-submit” (automatically logging in without having to specify HTML element IDs).
The update should be installed automatically the next time Firefox checks for add-on updates.
If you’d like to update manually, you can follow these steps:
  1. Open Firefox and navigate to about:addons.
  2. Click the gear icon (⚙️).
  3. Select Check for Updates from the menu.
Olivier Désalliers
All Comments (21)
Do you have “Automatically fill in credentials on load” and “Automatically submit the form after filling it” enabled in Extension Settings > Remote Desktop Manager Workspace?
Does it work when you manually select the entry in the extension popup?
For the equivalent URLs, you can add the URLs in the “Equivalent URLs” section of a Website entry. Where was your list of URLs before?
Olivier Désalliers
