New GUI with a lot of problems
A fix for this issue has been implemented in version 2026.3.16.0
Implemented
I'm running RDM 2026.3.9.0 64 bit and I'm experiencing a lot of problems related to the UI:
  • Navigation bar: title visible, content disappears
  • Moving a docket tab doen't allow to split window anymore
  • On web pages, a status bar that appears whilst browsing, interferes with the page’s behaviour
All Comments (8)
I found that the unpinned navigation bar is visible if Dashboard is the active tab.
Additionally, I found pinning tabs doesn't move them to the far left and dragging and dropping tabs is not functional.
The new UI is really buggy. I've noticed RDP sessions are noticeably slower in RDM vs. Windows RDP. This wasn't an issue in the old UI.
We should have a fix for the navigation bar not being accessible when in auto-hide mode in the upcoming 2026.3.10.0.
If the part you mention about the docked tabs not allowing a split view anymore being, for example, having 1 session shown then dragging a second session and docking it so it takes half the available space with the already shown session then that behavior seems to work for me in our internal build so it should work in the upcoming 2026.3.10.0 as well.
Could you tell us more information about what you mean with the status bar interferes with the page's behavior? Maybe a video of the issue could help us understand what's going on.
Best Regards,
Michaël Beaudin
Best Regards,
@Michael Beaudin
I attach a video.
On the right side Mozilla Firefox: I right-click on the icon, the menu appears, I click on the first item.
On the left side RDM: I right-click on the icon, the menu appears and disappears.
