ssh client
1) Switching between applications
rdm -> alt+tab -> other app -> alt+tab -> rdm -> entering commands in the console -> alt+tab -> other app -> alt+tab -> rdm -> loss of input focus
2) Pressing the button -> loss of input focus
Loss of input focus:
Thank you for reporting this and for the screenshots.
To help us confirm exactly what is happening, could you record a short screen capture showing the issue as it occurs?
Also, as a quick test in the meantime: when this happens, can you click on a different connection in the RDM list (it does not need to actually connect), then click back into the SSH session? Let us know if that restores keyboard input.
Thank you,
Samuel Dery
I've found and fixed the issue. You can expect this to take effect with the upcoming 2026.3.10 version.
Jafran Majeau
