RDM not pulling agent information for Gateways (using Devolutions Cloud)
A fix for this issue has been implemented in version 2026.3.12.0
Implemented
Hi guys,
Just noticed in RDM when clicking on the Administer Gateways tab. when i click on the desired gateway and then click on the diagnostics tab, i get a cross on the agent installed information even though i have a agent installed on gateway.
We use devolutions cloud as well.
All Comments (2)
Thank you for reaching out to Devolutions Support.
I was able to reproduce the issue you are experiencing, where the Devolutions Agent status is incorrectly reported as offline in the Devolutions Gateway diagnostic panel.
I will report this bug to our development team so they can investigate and work on a fix.
I will follow up with you as soon as a fix becomes available in a future update.
Jacob Lafrenière
If possible, could you update your RDM to the latest version (2026.3.12.0) and see if the problem persists? This version should resolve your issue.
Latest Version: Download RDM
If the problem persists after the update, please let us know so we can inform our development team.
Maxim Robert
