RDM v2026.3.5.0: Vault Folder Ordering Issue
A fix for this issue has been implemented in version 2026.3.8.0
Implemented
After updating to RDM v2026.3.5.0 today, my vault folders are out of order. I'm unable to drag them around. I also do not see a "Sort priority" option on the folders.
Edit: The "Sort priority" is there now (odd, I swear it wasn't earlier), but it doesn't work no matter what I change the folders to.
I go into DVLS and they are in the proper order that I originally created and set them to.
Apologies if I'm missing the obvious.
All Comments (4)
Update: Confirmed "Sort priority" does work but only when changing in RDM and then viewing in DVLS. They do not update in RDM and instead only show in alpha order.
We have a ticket opened for this already and we should have a fix for RDM 2026.3.7.0 (the .6 won't have it as it is already built and in our QA's hands for testing before release).
Best Regards,
Michaël Beaudin
This is ridiculous! Can you at least confirm that the new database version from 2026.3.5.0 is fully compatible with 2026.2.19.0?
Your data will be the same between 2026.3 and 2026.2. If you wish to go back to 2026.2 before this fix is pushed in 2026.3.7.0, you can.
If you are using a DVLS workspace and updated it to 2026.3, it is highly recommended to use the matching RDM 2026.3, but it is supported within a limited scope of activity like launching sessions. For example, if you try to edit users or users groups in RDM 2026.2 with DVLS 2026.3, you will be redirected to DVLS web instead of RDM's interface.
Best Regards,
Michaël Beaudin
