Recommended Answer
Following up on the log analysis: there is one more thing worth testing.
Looking at the log closely, RDM sends an environment variable request (LANG) right before the shell request, and the ASR rejects it. PuTTY, by default, does not send any environment variables at all, so this is actually a real difference between the two clients in how they talk to the ASR. It is possible the ASR's SSH implementation does not handle that request cleanly and this affects the shell request that follows it.
Could you please try this:
1. Right-click the "ASR01 Mgr 1" entry and select Properties.
2. Go to the Advanced tab.
3. Check the box labeled "Skip environment variable setup."
4. Click OK, then try connecting again.
Please let us know how it goes.
Thank you again for your patience while we work through this.
Alexis Geller Peiro
