Ability to use Privilege Account when using SQL Management Studio Add In
2 votes
You can currently using the 'My Privilege Account' option only when using the Windows Integrated Elevation, whilst this would be improved by allowing the 'Privilege Account' option. The main issue is you can't currently automatically use a database account to login, thus meaning the password must be made visible during checkout to be manually supplied to the client.
All Comments (5)
Hi @alexmoney,
Thank you for reaching out, we'll look into adding this option for you. We should be able to make it available fairly quickly.
Cheers,
Luc Fauvel
Hi @alexmoney,
Cheers,
@Luc Fauvel
Many thanks, I think it would make SQL management studio use quite slick
Was any progress made with this one?
Hi @alexmoney,
This should be available in the latest version of DVLS and RDM. All you have you to do is enable SQL management studio in the usage policies of your DVLS instance.
Cheers,
Luc Fauvel
Thanks, I updated RDM and Devolutions Server and turned on the policy, all working nice, much appreciated.
