what's the difference between filter and search (not advance search)
Backlog
Hi
Does anyone can tell me how to use this search function correctly, seems it not works, it couldn't match anything what I inputted. The filter or advance search function working as expected.
What's this search function use for?
All Comments (9)
Hello Neilson,
Thank you for reaching out about the search behavior in Remote Desktop Manager. Could you first clarify if the "search" you mean is the Quick Search option? You can find it described here: https://docs.devolutions.net/rdm/ribbon-menu-bar/view/search/quick-search#quick-search-settings
If so, Quick Search lets you search without displaying the tree view, and it has its own settings for which fields it matches against. You can adjust these settings by pressing the button inside the search bar, on its right side.
Could you also share an example of the value you typed, and where it exists on the entry, such as name, description, or host? That will help me confirm why it isn't matching, and check whether this is a known limitation.
Samuel Dery
Hi
See the screenshot as below:
I tried anything in this search, nothing really matched, it shows everything even I typed something already exist.
My search option setup as this:
Thank you for your reply.
This is indeed the "Quick search" for which I have linked the documentation:
With your current configuration, the search will only run after you press "Enter." You can change this by unchecking "Launch on Enter."
Something to note also: it is currently only looking in your "User Vault." You may want to enable the additional options if the entries you are trying to search for are located somewhere else.
Let me know if you are still encountering issues with it. From testing on my end, it seems to be working as expected.
Samuel Dery
