2 votes
This might already be there, but it like that you can right click an object to get name, username, password and other information. But I cannot get the IP address. This is important too for networking needs.
The option, might be copy host, host seems to be where the IP is located in the properties.
Yes, the "Copy host" button I believe is what you're looking for, assuming your IP address is located in the main "host" field of your entry.
Can you confirm this works for what you need?
This is no copy host option. i select name and it does in fact copy the name. See my options above.
It's difficult to tell since I don't see your entire context, but in your screen capture, I see the "Copy all hosts":
This button is the same as "Copy host", but when there's multiple values, it will copy all of them. In your case I suspect you've selected a folder containing multiple entries, is that correct? That's the only way I was able to reproduce this. If you select a specific entry like an SSH, the button should be "Copy host" and copy that specific host.
That seems to work, i will remember this but I would suggest renaming this to copy host to reflect what is being copied since it is copying the host information portion of the properties.
