Slow when opening a group of devices
I've noticed RDM can lag quite a bit when opening a selection of items. I've tried making Playlists for Opening a Selection of VNCs all at once, I get a spinning wheel for quite a while. Often times the RDM software will crash during this as well, but if it does open successfully it can take some time. I've experienced this with opening a selection of Web GUIs as well. It seems to open One Web Site at a time, waiting for one to open and load before going to the second.
All Comments (1)
Depending on how long it takes for each individual session to initialize, this may actually be expected behavior. Even when using a playlist, Remote Desktop Manager opens the entries one by one rather than launching all of them simultaneously.
Could you let us know approximately how long it takes to open a playlist of, for example, 10 entries? This will help us determine whether the behavior you're seeing is within the expected range or if there may be an underlying performance issue.
Looking forward to your feedback.
Carl Marien
